Outdoor Revolution Twin Burner Gas Camping Stove & Grill
£88.98 Inc VAT
Out of stock
Outdoor Revolution’s new and unique Twin Burner Gas Stove and Grill offers the perfect blend of high performance with compactness and style. Thanks to the braided hose with control valve which takes a Butane Propane screw fitting resealable gas canister, there is no need to use a separate hose and regulator with a refillable gas cylinder, which cuts down on space and weight during transportation. This is the only Twin Burner we know of in the market currently that has 2 burners and a grill that takes this type of high-power gas canister. You only pay for the gas you need to use when you are away whether it be for a weekend or an extended trip.
The Twin Burner Gas Stove and Grill is constructed from powder coated steel. It has 2 stainless steel high power 3 kW burners and a 1.4 Kw grill. Comes with a screw on- detachable braided hose with a solid brass control valve. Surrounding the burners is a pressed stainless-steel hob and there is an enamel grill pan with a datable handle. The stove comes with a hinged windshield on both sides that hooks and clips into the lid for extra stability giving a better cooking performance. The windshields fold down onto the hob and the lid can be locked into position for easy transportation.
- Twin burners: 2 x 2.3 kW
- Grill with grill pan and handle: 0.8 kW
- Lid with windshield
- Braided hose with control valve
- Construction: Powder coated steel construction
- Fuel: Screw type re-sealable butane / propane gas cannister
- Gas Consumption: 450g/h (all burners and grill on full)
- Ignition: Piezo ignition
- Heat control: Twist type
- Weight: 6kg
- Size: 51 x 36 x 41.5cm
COOK2105
Outdoor Revolution
