Formulated for maximum efficiency and minimum consumption, Jetboil’s high-performance propane/isobutane four-season fuel delivers higher vapor pressure for improved performance in cold weather. This 230g Jetboil JetPower Fuel can is easily packable and will fuel you through your next adventure.
- Fuel capacity: 230g (approx. 20 liters of boiled water)
- Ideal for use with Jetboil products
- Compatible with Flash, Joule, MicroMo, MightyMo, MiniMo, Stash, SUMO, Zip.
JF230
Jetboil
