Outdoor Revolution Pronto Compact 4 Panel Windbreak (125 x 500)
£157.00 Inc VAT
Out of stock
The Pronto Compact 4 Windbreak is a NEW compact version of our best-selling Pronto Windbreak, the fastest, simplest and most innovative windbreak on the market. Created for the outdoor enthusiast who is limited for space but needs extended privacy, the Pronto Compact 4 Windbreak is a premium lightweight four-panelled windbreak which simply pops up in a matter of seconds. Once pitched, it is incredibly stable, the fabric is the same robust 240HDE high density all weather lightweight fabric used in the latest Airedale & Movelite collections. The Pronto windbreak will be the quickest windbreak you have ever pitched, and will not let you down in windy conditions!
This Windbreak is produced from a contemporary printed 240 HDE High Density all weather lightweight Fabric that has been specifically woven to deliver exceptionally lightweight, yet durable products, allowing smaller pack sizes when folded, making it perfect where weight and space limitations are of key consideration, without limiting its robust nature.
Outdoor Revolution are the very first manufacturer to introduce the innovative pop up fiberglass frame system onto a windbreak, which can be effortlessly pitched within a matter of seconds, making this model ideal for impromptu touring excursion. The collapsibility of this frame makes it easier than ever to compactly pack away into the inclusive carry bag. The double central window panels allow you to keep an eye on the outside world, from the comfort of sitting behind the windbreak. Please note that this windbreak can be attached to your caravan, using the 6mm Kadar Strip on the left-hand side, in order to enclose your touring arrangement.
  • 240HDE high density all weather premium lightweight fabric
  • Designed to compliment the latest Airedale & Movelite ranges
  • Quick erect fibreglass pole pop-up system
  • Take apart fibreglass upright poles for extra strength & stability
  • Clear PVC window in 2 centre panels
  • Kader strip to both ends for attaching to a vertical awning rail & Screenhouse kader connector (2022 models)
  • Elasticated bungee peg down points to the base of each pole
  • Includes carry/storage bag, guylines and steel peg set
ORWB3010
Blue Diamond
Be the first to review “Outdoor Revolution Pronto Compact 4 Panel Windbreak (125 x 500)”
£157.00 Inc VAT
