This product really does work!
If you have a hole in your roof bellows/canvas or drive away awning this will repair it giving it a water tight seal.
Ultra high strength clear polyurethane polymer, has many other uses
- Permanent repair – no welding/separate adhesives
- Repairs Holes And Tears Instantly
- UV Resistant Inhibits Yellowing
- Cuts Easily To Any Size With Scissors
- No special skills needed – just thoroughly clean and dry the area to be repaired
- Cut strip to suit length of tear, peel off backing and apply. Full strength adhesion in minutes! Ultra high strength clear polyurethane polymer
Only needed on one side of repair
Our Package Includes:
- 1 x – 300mm x 75mm patch ( can be cut to size)
- 1 x – 35mm x 35mm patch
- 1 x – 22mm x 22mm patch
- 1 x 12″ Reinforcement Filament for repairing tears at edges
- 1 x Instruction set
Materials that this Tear Aid will be suitable for:- · Canvas · Leather (non-oiled) · Rubber · Nylon · Most Plastic & Paints · Plastic Laminates · Aluminium · Stainless Steel · Fibreglass · Polyurethane · Polyethylene · Polypropylene · Sunbrella · Gortex · Acrylics · Polyester · Hypalon · Dacron
TA1
BEWARE: There are fakes available of this product online, ours are 100% genuine Tear Aid and made in the USA
| Weight | .100 lbs |
| Dimensions | 36 × 35 × 6 in |
