Outdoor Revolution Campervan Pop Top Bed 7.5cm Self Inflating Mat – L180cm x W100cm
£74.99 Inc VAT
Out of stock
The Outdoor Revolution Camp Star Top of the Pop 75 self-inflating sleeping mat is new for 2021. The mat has been designed specifically to fit the Pop Top bed in the roof of a campervan, however, because of the extra deep 7.5cm dimensions, it will need to be taken out and folded away when not in use. The mat is inflated through 2 simple and reliable brass inflation valves located in the bottom corners which screw tight to lock in the air overnight. Easy to use, compact, and more comfortable than other specific Pop Top self-inflating mats on the market, for a better night’s sleep up top, go for the Top of the Pop!
  • The top fabric is made from 75D*150D Peach Polyester with an embossed PVC coating
  • The base fabric is made from 190T 75D Polyester Pongee with a PVC coating
  • Flat foam insulation at 75mm depth for extra a 3 Star Comfort Rating
  • Colour: Top – Adriatic Blue
    Bottom –  Monument
  • Supplied with a compression stuff sack with drawcord closure.
  • Supplied with 2 compression bands to help pack it away neatly.
  • Care instructions are provided.
Specification
  • Top Fabric: 75D*150D Peach Fabric, embossed with PVC coating
  • Bottom Fabric: 190T 75D Polyester Pongee with PVC coating
  • Foam: Flat
  • Carry Bag: 75D*150D Peach Fabric, embossed with PA coating
  • Valve: Screw Valve
  • Weight 4kg
  • Size 180 x 100 x 7.5cm
  • Pack Size 62 x 50 x 52cm
ORSM1009
Weight 3.4 lbs
Dimensions 66 × 30 × 22 in
Outdoor Revolution
Be the first to review “Outdoor Revolution Campervan Pop Top Bed 7.5cm Self Inflating Mat – L180cm x W100cm”
£74.99 Inc VAT
