Outdoor Revolution Camp Star Rock ‘N’ Roll King 120 Self-inflating Mattress VW California & Rib 112
(2 customer reviews)
£159.00 Inc VAT
Out of stock
We’ve been asking for this for a few years now, a self-inflating Mattress that is compatible with the VW California and The RIB 112 Rock and Roll bed – and Outdoor Revolution have listened!!!
Here we have the Campstar Rock N Roll King! 120mm thick for the ultimate comfort. A Fully reversible self-inflating mattress that can be used with both European factory-built campers and UK van conversions – using the RIB bed and similar sizes (please check)
The official sizes of this bed are 180cm x 112cm but after inflating one it is ever so slightly bigger at approx 183cm x 115cm – as the sides are rounded.
It is constructed from a robust Peach polyester on both the fabric top and base making it reversible and is constructed from a 12cm deep flat foam with horizontal drill holes making it lighter and more compressible in use.
The mat is inflated through 2 patented one-way Cyclone Valves located at the bottom of the mat that effortlessly inflates and deflates the mat quickly and efficiently.
This can be further topped up by using the Mini Max rechargeable fan if you prefer a firmer mattress.
  • The top and fabric is made from 75D*150D Peach Polyester with an embossed PVC coating
  • The base and fabric is made from 75D*150D Peach Polyester with a plain PVC coating
  • Flat horizontal drilled foam insulation at 10cm depth for a 4 Star Comfort Rating
  • COLOURS: Top Adriatic Blue
    Bottom Monument
    Side Dark Slate
  • Supplied with a compression stuff sack with draw cord closure
  • Supplied with 2 compression bands to help pack it away neatly
  • Care instructions are provided
Specification
  • Weight 4.8kg
  • Size 180 x 112 x 12cm
  • Pack Size 60 x 28 x 28cm (albeit not square)
  • Top Fabric: 75D*150D Peach Fabric, embossed with PVC coating (Grey in colour)
  • Bottom Fabric: 75D*150D Peach Fabric with PVC coating (Grey in colour)
  • Side Wall Fabric: 75D*150D Peach Fabric with PVC coating
  • Foam: Flat with horizontal drill holes
  • Carry Bag: 75D 150D Peach Fabric, with PA coating (Grey in colour)
  • Valve: 2pc Cyclone one way Valve (patented)
ORSM1029
Weight 3.4 lbs
Dimensions 66 × 30 × 22 in
Outdoor Revolution
Reviews (2)
2 reviews for Outdoor Revolution Camp Star Rock ‘N’ Roll King 120 Self-inflating Mattress VW California & Rib 112
  1. Mike Hopkins (verified owner)
    Just used our new mattress for the first time. Once I’d worked out the values rotate it inflated quickly.
    Made the California standard bed so much more comfy.
    Packed down easily this morning and popped back in its back. Perfect!
  2. Andrew Ingram (verified owner)
    Used for first time for wales trip. Made the RIB bed extra comfy! Just rotated the vales to squeeze out the air and rolled up with the quilt and put in the “ boot space “ behind the seat when put back into position. When needed, bed down and rolled into position ready made and rotated valves to inflate. Excellent!!
Add a review
£159.00 Inc VAT
