The lightweight, compact size, and multi-functional capabilities of our portable ‘4 in 1 Lumi-Fan Lantern’ makes the intelligent Solar/USB rechargeable 4 in 1 LED lantern light, fan, and Powerbank a modern-day camping essential! This fantastic accessory can be suspended from any of the designated hanging points in your tent or awning using an integral hanging hook and is also perfect for handheld use. The spotlights incorporate three brightness settings, ranging from a faint night light to a brilliant ceiling light, and a Mosquito safe Amber light. The large fan features three-speed options, to help you to adapt to the weather, in order to consistently maintain a comfortable temperature. A USB charging port has also been integrated onto this model, allowing you to conveniently charge up this Lantern overnight, or charge any alternative electrical devices, such as mobile phones, when not in use.
Compact USB & solar charging 4 in 1 Lumi-Solar Fan Lantern LED camping light. Featuring a 2000mAh power bank for mobile charging.
- 3x Speed Cooling Fan – low / med / high
- Multi-Function LED lights with 3 brightness settings
- Mosquito safe amber light setting
- USB & solar charging
- Power bank for mobile charging: 2000mAh
- Fold-out LED light panels
- Fold-out hanging hook
- Working Time: 4-8 hours
- Weight 0.4kg
- Size 14 x 14 x 11cm
ORBK0017
| Weight | 1 lbs |
| Dimensions | 21 × 21 × 21 in |
Outdoor Revolution
