This is the only Noseweight Gauge approved and calibrated to the British standard for these instruments. It offers calibrated precision, accuracy, reliability, and technical superiority over other Noseweight Gauges. It has a clear large scale to ensure the precise and safe loading for this safety-critical area, to ensure caravan stability when towing.
The Camping and Caravan Club conducted a study on Noseweight Gauges and found them to be inaccurate and unreliable. They then approached Milenco and asked if we could produce a Noseweight Gauge to the standard BS7961, which was written in 2004. At this time no one had produced a conforming gauge to the standard.
Milenco conducted studies on the available Noseweight Gauges and at best found them only accurate to within 12 kilos but more concerning is that we found these Noseweight Gauges often became ridiculously inaccurate with use.
- Rated up to 130kg
- Designed to by accurate after 1000 uses
- Scale is accurate to within 2kg
- Easy to read scale
2691
Milenco
