Leisurewize Dehumidifier Damp & Moisture Remover
£38.99 Inc VAT
Only 1 left in stock
SKU: 5026637665424 Category: Tag:
This compact low wattage electric humidifier is highly efficient in removing excess moisture at home, in a caravan or in a motorhome to help prevent mould & mildew, odours, condensation, peeling surfaces and rust.
It is simple to use, just connect it to the mains power supply and turn the unit on. And thanks to its compact design, it is ideal for use in wardrobes, bathrooms, kitchens and other areas that are prone to excess moisture.
  • Extracts up to 400ml of water each day
  • Water tank capacity: 1.3L
  • Auto-shuts off once the removable tank is full
  • Low wattage: 48W
  • LW573
    Weight 1.58 lbs
    Dimensions 26 × 22 × 30 in
    Powered With Oliver Pos
    Streetwize
    Be the first to review “Leisurewize Dehumidifier Damp & Moisture Remover”
    £38.99 Inc VAT
