Drive-away kits offer a secure way to attach your awning to your vehicle whilst still allowing you to easily drive away.
Simply attach the magnetic strip to the top of your vehicle, connect the figure-of-8 strip to the keder along one edge before attaching the awning beading along the other. To drive away, simply slide the figure-of-8 out, or detach the magnetic strip from the vehicle.
- 6mm keder to magnetic system
- Guying loops included for added stability (guy lines not included)
- 3 metre length
| Weight | 1.9 lbs |
| Dimensions | 97 × 8 × 7 in |
| Availability |
Kampa Dometic
