Easiest way to connect a driveaway awning to your vehicle if it does not have an awning rail
- 6mm to Limpet™ Fix System
- Simply attach the Limpets through the pre-cut holes in the driveaway kit and fasten to a smooth surface
- Supplied with 6 Limpets
- 3 metre length
9120000419
| Weight | 1.03 lbs |
| Dimensions | 97 × 8 × 8 in |
| Availability |
Kampa Dometic
