Hot water on tap. A mobile hot water system that will provide hot water through the tap or shower head. Ideal for camping, off-roading, dog shows, mobile catering, equine events, anywhere hot water is required!
- Continuous hot water – anywhere
- Hot water from the tap or showerhead
- Adjustable water temperature
- Heats to 25˚C above input temperature (temperature rise). Water can be re-circulated for higher temperatures.
- Strong water flow – 2.5 litres per minute
- Automatic ignition system
- Built-in safety features
- Comes complete with a strong carry case
- Carrying handles
- Works from most popular gas cylinders with appropriate regulator (not supplied)
- Heats water 30°C to 55˚C
- Complete with carry case
Specs
- Size: 31 x 24.5 x 30 cm
- Weight:8.4 kg
- Pump Hose Length: 1.5 metres
- Shower Hose Length: 2.5 metres
- 12V Lead length: 5 metres
9120000829
| Weight | 4 lbs |
| Dimensions | 33 × 26 × 32 in |
Kampa
Kampa Dometic
Reviews (1)
1 review for Kampa Geyser Portable Gas Hot Water System
Virginia Beckett (verified owner) –
This is a great piece of kit. The quick release water attachments make it easy to set up. I filled a Colapz bucket with (very cold!) water and recycled it for a few minutes. It didn’t take long at all to get it up to a ‘hot’ showering temperature. I have only tested it in the garden so far but plan to use it with a folding doggy padding pool as a shower tray!
