Lightweight Portable Inverter Generator
The Hyundai HY2000Si petrol inverter generator is a simple to use source of portable power.
Clean Reliable Power
With a massive 2000w / 2kW output and a low noise level of only 58dB you’re assured of a clean, quiet, reliable source of power whether you’re in a caravan, camping or a motor home.
Back-Up Power
It can also be used in an emergency at home or work, in the event of a power cut.
Small In Size, Big On Power
The HY2000Si comes with 2 standard 3 Pin sockets that will take any UK 13 amp 3 pin plug and also a 12V output for charging car or leisure batteries.
Pure Sinewave
Like all Hyundai generators, the HY2000Si produces a pure sinewave output, so not only will it power your fridge or lighting but can handle much more sensitive equipment, such as TVs, laptop computers, tablets and smartphones.
Safety Features
Built-in safety features such as digital overload protection and low oil shutdown will prevent any overloading or engine failure due to low oil levels and the easy to read backlit LCD display will show all the performance monitoring you require, adding reliability and worry-free operation.
Efficient And Economical
The large 3.8 litre fuel tank coupled with the efficient 80cc Hyundai 4 stroke engine, will give an ample runtime of up to 8 hours and the HY2000Si also has the benefit of ECO Mode setting, which will lower engine revs to meet the exact power demand, therefore saving fuel, reducing noise and extending the life of the generator.
No Messy Mixing
There’s also no messy mixing of fuel and oil, simply fill with fresh unleaded petrol and away you go, or the HY2000Si can be converted to run on LPG.
Compact, Lightweight Design
With the user in mind the lightweight, compact design incorporates a large carry handle and the tough exterior will protect against knocks and bangs, no matter what adventure you are on. The small footprint of this suitcase generator also makes it easy to store and simple to transport.
- Engine Model IC80
- Engine Type OHV – Single cylinder – 4 stroke
- Engine Size (cc) 80.00
- Oil Capacity (ml) 0.41
- Noise Level db (A) @ 7m 58.00
- Rated Speed (rpm) 4500.00
- Rated Power (kW) 1.60
- Maximum Power (kW) 2.00
- Start Method Recoil
- Fuel Tank Capacity (L) 3.80
- Run Time (hrs) up to 8
- Voltage (VAC) 230.00
- Frequency (Hz) 50.00
- Alternator Voltage Regulation Solid state regulator
- Casing Plastic
- Dry Weight – kg 21.00
- Gross Weight (kg) 28.00
- Dimensions (H x W x L) (mm) 280 x 455 x 510
Box Contents
- Inverter Generator
- Oil Filler Jug
- User Manual
- 12V Charging lead
- Tool kit
Hyundai
