Gallant ‘Lift Off’ TV Bracket for VW T4 T5 T6 T6.1 California, Caravelle, Campervan
£59.99 Inc VAT
Out of stock
The Lift off TV/Monitor Headrest Mount enables you to securely attach your TV to any headrest quickly and easily without the need for a permanent fixing. The mount is perfect for Campervans and Motorhomes, and can be moved to another seat or even another vehicle if you wish. The mount has the VESA Standard connecting plate with 75mm and 100mm hole centres and will hold most TV’s from 14” up to 27”. The lift off mounting plate retains the TV securely but allows it to be lifted off for storage or used in another location.
- The set comprises:
- Headrest Fixing Bracket
- 95mm Extension Arm
- TV Connecting Plate
- VESA Standard Lift Off Connecting Plate and Fixing Screws
- Fitting Instructions
Benefits:
No need for permanent fixing to your vehicle or cabinets
No tools required to fit the mounting bracket to the headrest
Adjustable to fit any headrest (with bar centres from 120mm to 160mm)
High quality sturdy aluminium construction
Holds TV securely in place
Allows swift removal of the TV for storage
Thumb screws to enable easy fitting and adjustment
Interlocking gears on each connection to give a solid and secure fixing
Compatible with the standard VESA 75mm and 100mm fixing hole centres
Fully adjustable
Fits screen size from 14” to 27”
Holds up to 10kg in weight
Adjustable Angles
The arm will rotate up to 180° from side to side
The mounting plate will rotate up to 180° from top to bottom
The mounting plate will also rotate through 360° enabling the TV to be levelled
| Weight | 0.85 lbs |
| Dimensions | 24 × 18 × 9 in |
4 reviews for Gallant ‘Lift Off’ TV Bracket for VW T4 T5 T6 T6.1 California, Caravelle, Campervan
You may also like…
£59.99 Inc VAT
Jean Claude (verified owner) –
(Google Translation) Superb product, I am very happy.
k.butterfield1 (verified owner) –
Great product, very sturdy
mrkoopsy (verified owner) –
Easy to fit, sturdy; tv fits behind passenger seat, over sink (clears sink lid if seat forwards). I’ve left tv on bracket while driving and seems fine.
ivanpaulfoster (verified owner) –
Brilliant well plsd
