The Colapz Flexi Waste Pipe is designed to make life that bit easier where waste pipe is required. Standard waste pipe can be difficult to pack away and once rolled up, where do you store them? Colapz have come up with a simple and effective solution which allows you to easily adjust the pipes to whatever length you want. You can also easily adjust the angle of them, so you can direct the water exactly where it needs to go. These flexible expanding pipes come in approximately 1 metre lengths, measuring 50cm in length initially, they then double in size once you stretch them out! You can decide what length you will need to reach the waste outlet from your caravan, and then it’s a case of simply expanding the tubes to the required length and connecting them to each other. The rubber end is designed so it can also attached to the standard 2 way “Y” connector which then goes straight into your waste outlets, or you can connect directly to the standard 29.5mm waste outlet. For those who have a smaller or larger waste outlet diameter, you can purchase separately an adaptor which will allow you to fit sizes from 19mm up to 50mm. Once your are ready to pack up and head home, simply disconnect them, rinse them through under a tap, give them a quick brush through inside to clear any residue or dirt. Then simply collapse, fold and pack them away, taking up very little space.
- No more long smelly waste pipes
- Easy to link and adjust to required length
- Easy to angle, so you can direct the water exactly where you want it to go
- Lightweight and robust, enhanced with quality UV stabilisers
- Easy to clean and store
- DOUBLES in length from 50cm to 100cm (1 metre)
- Fits standard caravan 29.5mm waste outlet
- Multiple lengths can be added and joined together extending to any length
Specifications
- Approximate length collapsed: 50cm
- Approximate length extended: 100cm
80035
Pennine Leisure Supplies
