Replacement Float Valve for Aquaroll/Aquarius/Rolly Polly
£13.99 Inc VAT
Only 2 left in stock
Mains water ball valve for use with 40 litre Aquaroll, Kampa Roly Poly, Sunncamp Water Buggy & Royal Aquarius
Enjoy a continuous supply of fresh water when using a super pitch in your caravan. Simply screw this into the side of your water hog or aqua caddy, attach a hose to it (using standard “hozelock” type connectors) and enjoy limitless water without ever refilling your water carrier
- Standard ‘Hozelock’ connector
- Flow valve assembly
- Great quality and fitted with a non-return valve as standard
ES2310
Pennine Leisure Supplies
