Low pressure Butane gas regulator for use with portable heaters range with 21mm Clip-on inlet connection, and effortless on/off lever to clearly indicate when your gas is switched on or off.
CALOR GAS approved with 5 year warranty
Fits:
CALOR GAS 15kg, 13kg, 12kg & 7kg Butane Cylinders.
CA721
| Weight | 0.86 lbs |
| Dimensions | 43 × 32 × 4 in |
