Fiamma Awning Skirting VW T5 & T6
This awning skirt is suitable for VW T5 and T6 campervans and helps protect from wind and rain. The skirt measures 2500mm in length and 420mm in height. It is quick and easy to fit as it requires no drilling of the vehicle, simply attach the elastic straps supplied with the awning skirt to your wheels and the rear panel has magnets to keep in place.
21368
| Weight | 1.5 lbs |
| Dimensions | 46 × 30 × 7 in |
| Availability |
Fiamma
Reviews (1)
1 review for Fiamma VW T5 T6 T6.1 Windbreak Skirting
anthonyabp (verified owner) –
What you see is what you get.
Need to supply your own pegs/ground fixings.
Magnets are very strong, so do not let them snap onto body work when attaching the wheel cover section unless you want the risk of an indent in the bodywork.
Also watch out for fine metal debris attracting to the magnet area as these will scratch paint, so wipe around magnet area before fixing to avoid this.
Finally, if you have alloy wheels, the bungee and hook are not long enough to attach to either wheel as shown for steel wheels and if you just hook the alloy, the hook will do significant damage to the paint.
You will need to buy additional bungees or tie straps to go round the arm of the alloy (standard devonport alloy) to avoid damage and give a secure attachment point.
Next a piece of external wide Velcro is needed to allow the overlap between wheel cover and cill skirt to be closed and held tight.
Without this (an extra magnet by design would have solved this) there is a risk that the side door clips this loose end and interrupts the door opening (if electric).
Finally, there are only 3 magnets on the cill piece so needs the tension of the bunge fixings to hold against cill. 2 more magnets would have made a much better fit.
So plus side does the job.
Downside needs a few tweaks and care in use to be a perfect product. at the price
