Tried and tested for over 12 months we have put together this 19” Smart 12v / 240v TV package for a T5, T6 and T6.1 vehicle (with original factory seats)
The package includes this Ferguson 19” Smart TV, The Gallant lift off TV bracket, plus a magnetic aerial which can be fed easily through the sliding window or the front door window and mountto the outside of the van. (We attach this to the metal scissor mechanism on our California – which can also boot reception if needs be) That said this little TV aerial gets good reception 80% of the time by just popping it inside the pop top roof too.
We find this package is the right balance of cost side and quality.
Smart TV
This 19” Smart HD Ready LED TV gives you online streaming content unlike any other Smart TV on the market. This TV comes with pre loaded popular streaming apps such as Netflix and Prime Video meaning you can simply relax into your world of TV entertainment.
Find catch up apps such as BBC iPlayer, All 4 and ITV Hub ready and waiting for you straight out the box. Please note you can not download any more apps to the TV.
This TV has built-in Wi-Fi for easy connection and also features USB inputs allowing you to record live TV, watch saved media and add an external keyboard with ease. The HDMI input allows you to use external devices such as tv boxes, PC’s and games consoles.
The ultimate flat screen TV with a thin depth and a lightweight design, ideal for wall mounting and also easy to move when you need to.
Gallant Lift of TV bracket.
The Lift off TV/Monitor Headrest Mount enables you to securely attach your TV to any headrest quickly and easily without the need for a permanent fixing. The mount is perfect for Campervans and Motorhomes, and can be moved to another seat or even another vehicle if you wish. The mount has the VESA Standard connecting plate with 75mm and 100mm hole centres and will hold most TV’s from 14” up to 27”. The lift off mounting plate retains the TV securely but allows it to be lifted off for storage or used in another location.
- The set comprises of:
- Headrest Fixing Bracket
- 95mm Extension Arm
- TV Connecting Plate
- VESA Standard Lift Off Connecting Plate and Fixing Screws
- Fitting Instructions
Portable indoor or outdoor Aerial
This aerial is designed specifically for Digital Reception. With a standard coaxial connection, it can be easily used with almost any portable or Living Room Television set.
Small, compact, and lightweight, it is perfect for Portable TVs and USB DTV Tuners. Easily carry it in your laptop bag or TV case without worrying about extra weight or space.
Its magnetic base enables you to use the surface area of large metal objects to enhance reception quality. Capable of receiving frequencies of VHF 174-230MHz and UHF 470-860MHz, it is ideal for both Freeview and DAB broadcasting.
Whether it is for your Bedroom, Kitchen, Caravan, Boat, or Car, the DTA240 is perfect for improving signal reception
Please Note:
Please note that reception also depends on the distance to the regional transmitter. Very thick walls, neon lights and energy-consuming electrical appliances (fridge, oven, air-conditioning, etc.) can reduce the capacity of the aerial. It is advisable to search for channels with a roof aerial and then use this small aerial.
On some TVs or Set top box, an integrated antenna power can be turned on to boost signal.
