This perfect ground anchor for the VW California rail system.
Ideal for securing luggage, bikes, pet carriers etc…
Pack of one
****Update – This kit is designed for the T5 seat rail system (California and Caravelle) with removable pieces within the front of the seat rail system. The T6 comes with sprung fittings on the front rails so you have to remove the end caps. The anchor points can be installed it involves removing all of the screws – inserting the plate and placing the screws back in – so not as straight forward as the T5 .****
UNQLASH
| Weight | .650 lbs |
| Dimensions | 18 × 13 × 14 in |
Reviews (3)
3 reviews for VW California Floor Rail Load Anchor/Lashing (Pack of One)
xlondonharbourmaster (verified owner) –
Absolutely perfect but do they really need to be this expensive, also I found the instructions very ambiguous? Hence only 3 stars
Michael Jenkins (verified owner) –
Fits my 2015 Cali (T5) perfectly and easy to install. Instructions aren’t very clear but once plastic end cap removed from floor rail then it’s fairly obvious how to secure. Quite expensive but very solid and well made so worth it.
pbswanbourne (verified owner) –
Really easy to install- I have a T6.1 Cali and wanted something to tether my dog (in harness) to when carrying two passengers in the rear. I was a bit apprehensive when the description highlighted that it would be more difficult to fit to a T6.1 than the T5 it was designed for but in reality it couldn’t have been simpler! Took no more than 10 minutes (and 5mins if that was looking for my correct socket set!). Means our Cocker Spaniel can now lie comfortably between the two front seats whilst being safely tethered to the fixing point.
My other concern was whether it would foul the bed when fully extended but good news is that the rear seat doesn’t need to slide all the way forward along the rails so there is still plenty of room for the fixing point – no fouling!
All in all the product does exactly what I wanted it to do, it is solid , well made and designed , easy to install / remove and safe.
