No pans needed with the Vango Scran Griddle Range! The non-stick cooking plate has the option of a flat or ribbed surface, providing a healthier cooking style and is simple to clean. The adjustable thermostat lets you set temperatures to your desired heat and the heat resistant handles make it easier to move around.
- 2.5m cable with UK plug – Extra long cable provides flexibility for cooking
- Power: 1500 Watts – Allows for efficient cooking
- Flat or ribbed non-stick grill plate option – Healthy cooking options and easy to clean
- Adjustable 5 setting thermostat with light indicator – Control the temperature whilst cooking (80-240oC)
- Heat resistant handes – for added protection
- Leg Height Adjuster – allows unwanted grease to easily drain away from food
Specifacation
- Weight:2kg
- Packsize: L64 x H13.1 x W29.5cm
ACQSCRAN B05TG9
Frequently bought together
| Weight | 2 lbs |
| Dimensions | 42 × 12 × 31 in |
Vango
