Vango Granite Duo 90 Table – Excalibur adjustable
Sitting 4 people and offering 2 height variances for versatility, the Granite Duo 90 is ideal for all outdoor adventures as the feet can be adjusted to ensure your table remains flat on uneven terrain.
With a lightweight and durable aluminum frame that folds into itself and a carry handle, the table is easy to store and transport.
It’s Granite effect table top gives a modern look and is extremely resilient, also easy to wipe clean.
- Table Surface – Lightweight and easy to clean
- Aluminium Frame – Lightweight and strong
- Adjustable Legs – Attach under the table for easy storage and compact folding
- 2 Table Heights – Table changes from a dining table height to a coffee table height
- Carry Case Design – No storage bag required
- Foldable to Compact Size – Easy storage and transport
- Adjustable Feet – Adjust height to variances in the ground level for stability
- Carry Handle – For ease and flexibility
- Maximum Loading Weight – 30kg/4st 10lbs
Specifications
- Weight 3.64kg
- Length 90.0cm
- Width 60.0cm
- Height 71.0cm
- Max Load 30kg
TBNGRANITE27075
Vango
