Vango Granite Duo 120 Foldable Adjustable Camping Table
The Granite Duo 120 has a large granite effect table top and can seat up to 6 people comfortably.
Simply adjust the legs to stand at coffee or dining table height and alter the feet to ensure a stable surface on uneven ground.
It’s ideal for use in your garden or camping as it’s lightweight and compact, making it easy to store and transport to and from the campsite.
- Aluminium Frame – Lightweight and strong
- Table Surface – Lightweight and easy to clean
- Adjustable Legs – Attach under the table for easy storage and compact folding
- 2 Table Heights – Table changes from a dining table height to a coffee table height
- Carry Case Design – No storage bag required
- Foldable to Compact Size – Easy storage and transport
- Adjustable Feet – Adjust height to variances in the ground level for stability
- Granite Effect Table Top Design – Gives a modern look and is extremely resilient
- Carry Handle – For ease and flexibility
- Maximum Loading Weight – 30kg/4st 10lbs
Specifications
- Weight 5.82kg
- Length 120.0cm
- Width 80.0cm
- Height 71.0cm
- Max Load 30kg
TBNGRANITE27086
Vango
