Make your awning a home by adding warmth and comfort underfoot with a Vango Carpet. Fitted to specifically match your awning, this Vango carpet is an added luxury you wont want to be without
Works with both Left Hand and Right Hand versions of the Galli and Rhone.
- Neutral colourway to suit all.
- Corner branding for easy positioning and identification
- Woven nylon top for durability
- Foam mid-layer for added insulation and comfort
- PE waterproof, non-slip base
- Easy to clean – Can be brushed, vacuumed or cleaned with a damp cloth if required
- Supplied with a handled carry bag
- For use with Vango Galli III & Rhone
- Carpet Dimension: 379 x 294
CPS000100W11Z01
| Weight | 3.5 lbs |
| Dimensions | 56 × 47 × 20 in |
Vango
