Vango Airbeam Tempest Rechargeable Pump
Designed for not only the Vango Air Awnings and Tents, but also other brands such as Outwell, Outdoor Revolution, and Kampa; the Vango Airbeam Tempest is a rechargeable pump which is easy to handle and store.
Features include an LED screen, a USB output port, a variety of adaptors, and a built-in auto cut-off that automatically stops when it reaches its set pressure, which makes setting up alot more efficient.
The Airbeam Tempest also features a two-stage motor designed to increase airflow, allowing quick inflation or deflation of your tent, awning, or other inflatable camping gear.
What am I compatible with?
- Any Self-Inflating Mat (SIM) with a Cyclone Valve
- Bravo Adaptor – Compatible with several other inflatable tents
- Boston Adaptor – Compatible with a variety of other inflatable products
- 130cm Hose with Multiple Adaptors – Provides versatility to inflate a range of product
- Inflates and Deflates – Quick and easy for a simple set-up and a fast pack-up
- USB cable included – charge directly from any standard USB port
- Rechargeable Lithium Battery 2000mAh/90W – Never have to buy batteries again
- Inflates to Max 10PSI with Auto Cut Off – Perfect for inflating tents, awnings and inflatable chairs
- 2 Stage Motor – Airflow 500L/Min & 40L/Min – Gives increased airflow in to your product which means the beam or the product will be able to inflate faster
- Charging Time – 5V2A – 3 hours & 9V2A – 2 hours
- Runtime – 30 mins – Ensures you get all of your equipment set up for your camping trip
- Working Noise = 75db – Quiet inflating device which won’t disrupt other people on the campsite
- Power Bank Function – Rechargeable via USB-C, with a USB output port. (Charging cable included).
- LED Display Screen – Allows you to see how inflated your equipment is on the screen
Specifications
- Weight 1.06kg
- Height 9.2cm
- Width 8.7cm
- Length 26.4cm
ACVPUMP00000001
Vango
