Thule Omnistor 5102 Full Roll-Out Awning (for use VW T5 T6, T6.1 and the California)
Price range: £239.99 through £879.99 Inc VAT
If you have a factory T5/T6 van that has been converted – please check that you have the roof bar preparation kit/rail as per picture 4. If not this awning will not fit. (you will need a fiamma f45s with an additional fitting kit)
If you have a factory T5/T6 van with a pop top fitted with rear scissor hinges – again this kit will not fit. (you will need a fiamma f45s with an additional fitting kit)
The Thule Omnistor 5102 awning is the same awning that Volkswagen supply as the factory fitted wind out awning on the California, we can supply the awning with the standard fitting for a van with roof bar preparation or complete with the full OEM kit to attach it to the California.
- Exclusively for your Volkswagen, T5 T6 California or Transporter.
- We only stock the latest version that has no seam meaning the fabric is all in one piece
- Fitted to the side wall by means of california brackets available to buy in the shop
- Top quality, durable, weatherproof and colour fast PVC-coated fabric to protect against UV and rain
- Including a fast gear, operated by the user-friendly telescopic gear, for effortlessly opening and closing the awning.
- Smart, adjustable legs integrated in the front profile give more clearance and stability when in use.
- Vertically lowering system to unfold support legs without danger of damaging the vehicle.
- With user friendly Quick Lock system for easy setting and adjustment of the support legs.
- length 2.60 m.
Please Note: If using with VW California fitting kit you will need to drill two simple extra holes, if you need more information please contact us as we will be happy help
PLEASE ENSURE YOU INCLUDE A DAYTIME PHONE NUMBER WHEN PLACING YOUR ORDER THAT WILL BE PASSED TO THE COURIER
WE CAN ONLY SHIP THIS ITEM TO MAINLAND UNITED KINGDOM
| Colour/Option | Light Grey T5/T6/T6.1, Anthracite T5/T6/T6.1, Light Grey with VW T5 T6 T6.1 California Fitting Kit, Anthracite with VW T5 T6 T6.1 California Fitting Kit, VW California T5 T6 T6.1 Fitting Kit Only |
Thule
You may also like…
Comfortz VW California Awning Kit / Camping Room with Windows
Original price was: £449.99.£399.99Current price is: £399.99. Inc VAT
