If you are looking for a comfortable, practical and durable portable toilet that doesn’t require a connection to a drainage or water system, Thetford has the perfect solution for you: the Porta Potti 145.
- Developed by the inventor of the portable toilet
- Lightweight, high-quality, durable plastic
- Choice of flushing system
- Easy and convenient emptying
Specifications
- Capacity of flush-water tank 15 L
- Capacity of waste-holding tank 12 L
- Comfort class 3/5
- Dimensions (hxwxd)330 x 383 x 427 mm
- Flushing system Bellow pump
- Level indicator display for the flush-water tank – No
- Level indicator display for the waste-holding tank – No
- Net weight 3.6 Kg
- Seating height 324 mm
- Size Medium
Thetford
