Tear Aid Fabric and Drive Away Awning Repair Tape 3″ x 5ft Roll (Type A)
£26.99 Inc VAT
Only 1 left in stock
Tear Aid Type A Fabric Repair Tape (3inch x 5 foot) roll
This product really does work!
If you have a hole in your roof bellows/canvas or drive away awning this will repair it giving it a water tight seal.
Ultra high strength clear polyurethane polymer, has many other uses
- Permanent repair – no welding/separate adhesives
- Repairs Holes And Tears Instantly
- UV Resistant Inhibits Yellowing
- Cuts Easily To Any Size With Scissors
- No special skills needed – just thoroughly clean and dry the area to be repaired
- Cut strip to suit length of tear, peel off backing and apply. Full strength adhesion in minutes! Ultra high strength clear polyurethane polymer
Type A (fabric) | Type B (vinyl)
| Weight | 0.1 lbs |
| Dimensions | 10 × 9 × 10 in |
| Availability |
Tear Aid
