The perfect canopy for protection from the elements – stylish and easy to set up.
- Two side picture windows
- Steel and fibreglass frame
- 1 x aluminium roof pole included
Specifications
- Height Range 235 – 250cm
- Floor plan size 390cm width x 240cm depth
- Approx. pack size 79 x 18cm
- Approx. weight 7KG
Please be aware this product is designed to be raised slightly off of the ground. – If you require something that seals to the floor take a look at the Sunncamp 390 porch awning.
SF8000
Frequently bought together
| Weight | 8 lbs |
| Dimensions | 83 × 22 × 22 in |
