Rocket low wattage cream stainless steel kettle (1.7L)
£29.99 Inc VAT
SKU: 5055924812333 Category:
R
Quest 1.8LRocket low wattage cream stainless steel kettle (1.8L) A premium quality low wattage stainless steel kettle. The main body of this kettle is stainless steel, making it stronger and last longer than its cheaper rivals. It has a large capacity of 1.8L, which is perfect for making more drinks and less fill ups. It features and easy to read water level indicator on the side and is finished in a premium quality high gloss finish which means it looks as good as it performs. The kettle is also easy to clean and maintain. The safety cut out, power indicator light, boils dry protection and manual override add control and safety to the kettle at all times. Being low wattage it draws very little electric (1000W), which ensures it will not trip any campsite electric and ensuring you can use it anywhere. It is also cordless which means the cord is attached to the base and not the kettle. This means when you pick the kettle up it is not attached to the socket making it easier and safer to use. It also means you can leave the base plugged in where required and still fill the kettle without having to unplug the base.
Low wattage Cordless Stainless steel Premium quality Water level indicator Easy to clean Power indicator light Manual override Boil dry protection Safety cut off
Material: Stainless steel Colour: Cream Capacity: 1.7L Size (with base): 22 x 15 x 24 cm Weight (with base): 0.95 kg Cord Length: 80 cm Voltage: 230V Frequency: 50/60 HZ Wattage: 1000W
Quest
Be the first to review “Rocket low wattage cream stainless steel kettle (1.7L)”
£29.99 Inc VAT
