Quest Rocket 2-Slice Cream Stainless Steel Low Wattage Toaster
The Quest Rocket 2-Slice Cream Stainless Steel Toaster is a premium, low-wattage appliance designed for efficiency and style. Its compact design and 900W power consumption make it perfect for caravans, motorhomes, and campsites, ensuring it won’t trip campsite electrical systems.
Constructed with a durable stainless steel body and a high-gloss cream finish, this toaster not only adds a touch of elegance to your kitchen but is also easy to clean and maintain. The adjustable browning control, along with reheat and defrost functions, provides versatility to toast both frozen and regular bread to your preferred level of crispness.
Features:
- Low wattage (900W) – ideal for campsite use
- 2-slice capacity – compact and space-saving
- Durable stainless steel construction with high-gloss cream finish
- Adjustable browning control for perfect toasting
- Reheat and defrost functions for added convenience
- Removable crumb tray for easy cleaning
- Power indicator light and manual override
Specifications:
- Dimensions: 26 cm x 14.5 cm x 17 cm
- Weight: 1.2 kg
- Cord Length: 75 cm
- Voltage: 230V
- Frequency: 50/60 Hz
- Wattage: 900W
Quest
