Quest Barbuda Low Wattage Ceramic Heater – 230v/500w
£21.99 Inc VAT
Only 1 left in stock
Small in size, the Quest Barbuda is easy to use in virtually any environment; from campervans and motorhomes to offices and student dorms, it is sure to heat up the space nicely.
Being Low Wattage at just 500w ensures the Barbuda takes up minimal electricity and can be used alongside other appliances when using campsite electric supplies.
The Quest Barbuda is lightweight, weighing just 0.7kg allowing you to store it almost anywhere when not in use and it adds virtually no weight to your camper.
Boasting a premium heating element, full temperature control and directional heat; the Barbuda is a small but mighty heater, perfect for colder months.
There’s no need to worry about the safety of the heater, with a tip-over switch and over heat protection being important features.
Low Wattage
This is a low-wattage heater so it draws less electricity than a standard heater. This means that it is cheaper to run and far less likely to trip your site’s electric supply. Some sites now only allow or request low-wattage items, meaning this heater can be used at all times whereas a standard radiator would not be
Full Temperature Control
The heater has a thermostatic temperature control on it which allows you complete control over the temperature, allowing it to be set at the preferred temperature.
Specifications:
- Heat: Ceramic Heating Element
- Voltage: 230v
- Frequency: 50-60Hz
- Wattage: 500w
- Size: 12.5cm x 11.7cm 18.5cm
- Weight: 0.7kg
E0092
