Patio Gas 27mm Clip-on Regulator 37mbar
- Butane Gas Regulator – Clip On Type
- Fully tested and approved to BS & EU safety regulations, Operating Pressure = 28 mbar. Outlet = 8mm Nozzle.
- Ideal for use with our gas paella burners as long as you have the correct gas bottle for this regulator type.
- Also can be used with BBQ’s, patio heaters and other portable LPG gas appliances.
T27CLON
| Weight | 0.86 lbs |
| Dimensions | 43 × 32 × 4 in |
| Availability |
