Zipped around the side stays of wind-out campervan awnings, the Outwell Fallcrest Tarp Side Panel Set can either be used on its own or extends the versatility of the Hillcrest Tarp even further. Flexible privacy and protection is set up in just a few minutes with reliable stability assured through the use of guylines and ground pegging points. Both panels can be rolled up partially and secured by toggles whilst still offering protection from the elements.
- Provides shade, shelter and privacy
- Attaches to wind out awning or roll out awning
- Angle from awning or vehicle can be adjusted
- Can be partially or completely rolled up
- Rear panel is shorter than front panel to allow for easy use of sliding door
- Can be used with king poles (not included)
- Attaches using heavy duty Outwell zips
- Fast and easy to attach and detach
Specifications
- Flysheet:Outtex® 3000 Select, 100% polyester
- Hydrostatic Head:3000 mm
- Attachment height:175 – 200 cm
- Pack size:45 x 32 x 5 cm
- Weight:1.3 kg111228
Outwell
Reviews (4)
4 reviews for Outwell Fallcrest Side Panel Set
You may also like…
Outwell Hillcrest Tarp Privacy Shelter
Original price was: £88.95.£80.71Current price is: £80.71. Inc VAT
claremacrob (verified owner) –
These are great – super easy – 2 minute job to zip onto awning arms and peg in, and just as quick to put away, then they pack down to nothing. They create a good wind-break and give the feeling of extending your space with minimal faff.
Lucinda Dixon (verified owner) –
These side panels saved our rainy holiday in the Lake District! So quick and easy to zip on and off and gave extra dry space under the awning when it was pouring with rain.
Thanks also for the brilliant service getting these sent out last minute so that they arrived in time to take on holiday!
acooper (verified owner) –
Purchased Hillcrest and Fallcrest for rainy and windy days. Simple and effective design for erecting a room around the VW awning without creating an enclosed box. Easy to dry, and stow away.
Yet to test in adverse conditions but quality looks goods and CampervanBits good to deal with.
alangjackson (verified owner) –
Not used in the field yet. very lightweight, quick and simple to fit, good quality. pack away to nothing and fit nicely into the tailgate with the chairs.
