Outdoor Revolution Single Induction Hob 1800W
Featuring temperature controllable 1800W single induction hob with over-heat protection and timer, the Outdoor Revolution single induction hob is the perfect, safer alternative cooking source in comparison to other live flame gas cookers.
There are ten different functions on the hob making it extremely versatile for trouble-free cooking: power, temp, keep warm, hot-milk, boost, timer, up, down, On/Off.
The top is very easy to keep clean, and the non-slip feet add extra support. Simply wipe down once cool enough.
Many non-Stick pots and pans will not be compatible with induction hobs due to the aluminium.
Features:
- Functions & Features:
- Temperature range: 60°-240°C
- Timer range: 1-180 Minutes
- 10 function control: power, temp, keep warm, hot-milk, boost, timer, up, down, On/Off
- Control panel safety lock function
- Pot recognition with over-heat protection
- Power: 220-240V~50/60Hz 200-1800W Includes UK to EU plug socket converter
- Certification: GS, EMC, LVD, ROHS, UKCA, CE
- Weight: 2.35kg
- Size: 28 x 34 x 6.6cm
COOK2125
Outdoor Revolution
![5336618-po222-2-3-560[1]](https://pos.vwcaliforniaclub.com/wp-content/uploads/2025/06/5336618-po222-2-3-5601.jpg)
