Outdoor Revolution Portable PTC Oscillating Ceramic Heater 750W/1500W
£19.99 Inc VAT
Out of stock
Outdoor Revolution’s new Portable PTC Ceramic Heater is compact yet powerful and swiftly warms up the living space in your tent, campervan, and caravan where mains electricity is available. This small heater kicks out between 750W and 1500W of heater power and has an oscillating function to ensure a balanced flow of air, there is also a ‘Fan Only’ setting which will circulate the room temperature air during the warmer months. The heater is easily controllable for the most comfortable room air temperature thanks to the built-in thermostatic controller. The heater comes with a European adaptor so can be used on the continent. Always on hand for a camping trip, travel, and as an emergency heater around the home and in the office
Made from lightweight ABS material, the heater is compact, lightweight, and extremely portable.
If Camping it is essential to have a source of electricity to power this appliance, our Mobile Mains Power Unit with USB and an 18-metre-long cable- OREL1000 will do just that job!
- Variable heat and fan speed control including Fan Only setting
- Oscillation function
- Automatic safety tip-over protection
- Overheating cut off protection
- ABS housing construction
- Includes UK to EU plug socket converter
- Certification: CE, ROHS
Specifications
- Weight 1.35kg
- Size 18 x 15.6 x 25cm
- Power 220W-240V~50Hz, 750W/1500W
HEAT2113
