Outdoor Revolution Portable Gas Heater
Original price was: £36.99.£34.99Current price is: £34.99. Inc VAT
Out of stock
Outdoor Revolution’s new Portable Gas Heater is very compact, and easy to use. This heater has an impressive 1200W power output and is compatible with our own Iso Butane 220g Gas Cartridges. Employing some clever safety features makes this gas heater the safest on the market, incorporating a tilt switch that will automatically shut off the gas flow if the unit is accidentally knocked over, and an ODS valve that cleverly shuts down the heater if the oxygen level gets too low (Oxygen Depletion Sensor). Ideal for camping and fishing trips in the colder months, or as an extra heater in any outdoor space or in any emergency.
The Portable Gas Heater is very easy to use and is ignited with a built in Piezo Ignition switch. The heat output can easily be controlled by the twist and turn knob on the side. It is robust and made from enamelled steel body with a chrome plated wire fire guard covering the ceramic burner plate. The heater comes with easy to follow step by step guides to get the best performance and highlights how to stay safe when using the appliance.
Features/Specs
HEAT2100A
Outdoor Revolution
