Outdoor Revolution Cayman Outhouse Handi Drive Away Utility Awning – Low
£174.99 Inc VAT
Out of stock
BESTSELLING LIGHTWEIGHT POLED SMALL DRIVE-AWAY UTILITY TENT
The bestselling lightweight Cayman Outhouse Handi pole-and-sleeve Drive-Away awning functions as a compact multi-purpose utility tent, which can be fixed alongside a campervan or motorhome and carries freestanding capabilities. A perfect addition to any touring arrangement, granting an indispensable extension of usable space, making it perfect for use as dining, cooking, relaxation, storage, pets, toilet, or shower area. Now available in 2 ergonomic cowl sizes to fit a vehicle rail height of up to 255cm, the Outhouse Handi is very simple to pitch using just 2 robust fiberglass poles. We have introduced crystal clear window panels and mesh ventilation points on both sides of the awning to maintain an airy internal space, and a separate peg-down groundsheet giving the option to remove if desired. Exterior zip-down storm covers help to ensure maximum protection against the elements throughout adverse weather conditions, whist roof ventilation points ensure airflow is maintained to reduce condensation. A stylish front canopy can be created using optional canopy poles (available separately), and the internal area can be illuminated in the evening using our optional Lumi Link lighting system which velcros simply into place.
This model has been produced from a premium ultra-lightweight 120HDE fabric weave, which has been specifically engineered to deliver lightweight, compact, and visually contemporary products that pack away neatly into the inclusive carry bag, making it perfect where weight or space limitations are of key consideration. This material incorporates a 3,000mm Hydrostatic Head and employs fully taped seams throughout, meaning it is exceptionally waterproof and rain will simply bead onto the surface, before rolling off. The sleek design lines & classic tricolor livery will coordinate & complement any campervan or motorhome.
The Cayman Outhouse Handi comes complete with a Peg-Down PE groundsheet, steel ground pegs, and reflective guylines. Optional Canopy Poles are also available for purchase, alongside an array of other convenient accessories.
- 120HDE high density all-weather lightweight fabric
- Hydrostatic head 3000mm
- Lightweight yet robust fiberglass poled frame
- Zip-up canopy style door – Canopy poles sold separately
- Inner cowl tension straps and cowl bungee for an adjustable vehicle fit
- 4mm & 6mm twin cowl connection rail piping
- Roof ventilation system with Velcro down storm cover
- Side Phoenix mesh ventilation with roll-up external cover
- Separate peg down PE groundsheet
- Colour coded guylines with quick adjusters
- Adjustable webbing pegging system
- Includes peg set and carry bag
- Total Weight: 6.5kg
- Pack Size: 66x25x38cm
- Footprin:t 200 x 200cm (+80cm cowl depth)
- Height: 180cm-210cm
- Rail Connection Width 212cm
ORDA1200
Outdoor Revolution
You may also like…
Thetford Porta Potti 335 Toilet
Original price was: £104.95.£98.99Current price is: £98.99. Inc VAT
