Outdoor Revolution Alu Top Camping Table 80 x 60cm
£29.99 Inc VAT
Out of stock
The Outdoor Revolution Alu Top Camp Table is no ordinary camping table, it is in fact a lightweight camping table with a heat proof & waterproof aluminium top, which is ideal for washing up or cooking on. The ‘U’ shaped locking legs spread the table weight, making it kind to groundsheets and afterwards it can be folded completely flat for easy storage. The side handle makes the table very easy to carry and transport. All in all a strong, versatile and quality camping table that has several uses when space is at a premium.
Product Code: FUR2140
The table has a strong aluminium sheet top with plastic reinforced corners.
The legs are made from an attractive powder coated foldaway steel frame for added strength and compactness.
• Tabletop: Heatproof Aluminium sheet with a powder coated finish
• Legs: 19mm diameter steel tube with 0.7mm thick wall
• Base- U-shaped legs with rubber stabilizing feet on rounded corners
• Carry Handle along the longest edge
Total Weight 5.1kg
Size 80 x 60 x 70cm
Max Load 30kg
Barcode 5060542056137
