This multi-purpose trolley is great for transporting your camping gear from your vehicle to pitch. With its large capacity and sides you are able to load various shaped and sized items with ease. The Trucker can also be used on other occasions such as beach trips, festivals or even around the home etc.
Quick to set up and fold
Large wheels, front swivel
Heavy duty steel frame
Durable polyester material
Max load: 100 kg on smooth ground
Open size: 92 x 50 x 59 cm
Packed size: 82 x 19.5 x 32.5 cm
Weight: 12.2 kg
9120001288
| Weight | 11.01 lbs |
| Dimensions | 84 × 21 × 34 in |
Kampa
Kampa Dometic
