The Kampa Space Saver Deluxe saucepan set with steamer/colander is made from high quality steel stainless, has heat resistant silicon handles and 3 glass lids. The 3 piece space saver pan nest together for compact storage ideal for the space conscious camper. With the Space saving design takes up less room on the hob. Can be used on gas or electric hobs . Encapsulated base for even heat distribution and enhanced cooking performance.
- 3 Steel pans
- 1 Steel steamer/colander
- Space saving design, pans nest together
- Heat resistant silicone handles
- Encapsulated base
- Complete with tempered glass lids
- Hand wash only
Specifics
- 14 x 13cm saucepan
- 16 x 15cm saucepan
- 18 x 17cm saucepan
- 18 x 8cm steamer (fits 18 x 17 cm saucepan) can be used as a colander
9120000477
Frequently bought together
| Weight | 3.25 lbs |
| Dimensions | 41 × 23 × 21 in |
Kampa Dometic
