The Easy Awning Pulley from Kampa makes threading your awning onto the caravan a simple, one person task. Simply slide the pulley into place, lock into the caravan beading channel, and attach the carabiner to the eyelet on the awning beading. Then using Kampa’s unique pulley system, effortlessly slide your awning along the channel to the desired position.
- Pulley system makes threading your awning onto the caravan a one person task
- Large cushioned padding to prevent damage to the caravan
- Reinforced sewing points
Instructions for use
1. Slide the awning stopper and pulley into place in the caravan beading channel. Lock into position.
2. Attach the carabiner hook to the eyelet on the awning beading.
3. With one hand, place the beading into the channel and pull on the spool away from the caravan. You can now slowly walk backwards to pull the awning on to the caravan channel rail.
9120000404
| Weight | 0.75 lbs |
| Dimensions | 12 × 17 × 22 in |
| Availability |
Kampa
Kampa Dometic
1 review for Kampa Awning Easy Awning Pulley
Michael Bell (verified owner) –
The Awning pulley locks will never fit as the pulley rail on swift will only take 6mm pulley locks. Had to struggle putting my awning on again as this pulley system locks are 8mm wast of time NOT HAPPY
PS I don’t think this pulley lock will fit any touring van rail
