The Heat Holders® Ladies Neck Warmer is ideal for keeping out the chill this winter. The Neck Warmer is made from Heat Holders® 3.5 Tog Heatweaver Yarn that helps to protect against the cold and wicks away moisture to keep you dry and comfortable.
The Neck Warmer offers an attractive cable knit outer with a super soft fur-like lining that helps to hold warm air against the skin for longer and a specially sculpted fit that contours around the chest, neck and chin. Machine washable at 40 degrees.
52% polyester 48% acrylic outer. 100% polyester lining.
BSJH701OSBLK
Heat Holder
