The Elsan Grey Water Tank Fresh helps to get rid of your water drains stale odours, But Tank Fresh doesn’t just mask smells from your sinks, showers and drains, it eliminates them completely from your grey water system. When used regularly, Tank Fresh also dissolves grease build-up to help keep everything clean, fresh and free flowing.
Once you’ve tried it, you’ll never put up with bad odours from your grey water system again.
- Eliminates grey water odour
- Dissolves grease
- Helps keep the system clean, fresh and free flowing
| Weight | 2.3 lbs |
| Dimensions | 34 × 15 × 13 in |
Elsan
