This is the excellent Quest collapsible electric kettle. This kettle can be collapsed when not in use, so it is ideal when space is at a premium. Not only does the kettle collapse down when not in use, but the handle also folds away into the lid making the packed size even smaller.
The kettle itself is low wattage allowing it to be used on sites without the danger of tripping the electric. The fact that it collapses when not in use makes it extremely easy to store away. The power indicator lets you know when the kettle is on and the automatic cut-out switches off when the water is boiled.
- Collapses when not in use
- Handle folds away
- Low wattage
- Easy to use
- Easy to store away
- Power indicator
- Automatic cut off
Specifications
- Size: 18.5 x 13.5 x 18 cm.
- Collapsed: 13.5 x 13.5 x 10 cm.
- Capacity: 0.6L.
- Weight: 0.54 kg.
- Voltage: 220 – 240v
- Wattage: 750w
- Hertz: 50/60Hz
K0026
Frequently bought together
| Weight | 0.7 lbs |
| Dimensions | 19 × 14 × 14 in |
Quest
