Camptech Cayman Traditional Full Caravan Awning
Price range: £529.00 through £768.00 Inc VAT
Our Cayman Awning has proven to be a firm favourite for those who are seeking to buy inexpensive quality touring awning. This awning is perfect for your holidays or a weekend mini break. Available in sizes 4 to 19
If you’re a caravanner looking for a great awning, look no further than the Cayman Touring Awning. A rising star in the market which has already enjoyed huge success, many people consider this awning great for beginners or those experienced caravanners who are looking for extra living space whilst on holiday.
The wall material of our Cayman Touring Awning is produced in our Climatech SR17 coated polyester, this material makes your awning easy to clean and very durable. The roof material of our Cayman Touring Awning is produced in our Climatech SR18 all season coated polyester, this is a superior grade material which helps makes the roof of your awning durable during your touring periods. The Cayman Steel 22/25mm frame is fitted with our unique Griploc clamps. Included with the frame will be Uniloc pads to assist in fitting the frame to the side of your caravan. This awning features roll back front panels which are great for an optional wide front door and large windows which are excellent for enjoying the view. The Cayman also features the option for you to have those well sort after veranda windows (veranda bar optional). Our touring awning is also supplied with modern design curtains so you can create a private space during the day or in the evening.
One of the many features you will find on the Cayman Awning is the sewn in Techline buckles on either side of the awning, which allow for the easy attachment of our optional Techline Secure Strap System. Located on the front apex is a large ventilation panel that can be opened or closed during use.
- Uniloc Pads
- Techline Zips
- Draft Skirt
- Wheel Arch Cover
- Curtains
Specifications
- Available in sizes 4 to 19
- Depth – 240cm
- Colour – Anthracite/Light Grey
- Weight – Approx 23.5kg (for a size 8)
- Frame – 22/25mm Steel Frame
To enhance your Cayman Touring Awning we also have the below optional extras:
- SL500 Techline Secure Straps
- SL580 Techline Secure Plus Strap
- Protech Roof Raiser Pole
- Veranda Poles
- Standard or Tall Annex
- Inner Tents (to be used with the Annex)
- Storm Legs
- Roof Rafter Poles
- LED Lighting System
| Sizes | Size 10 (875 – 900cm), Size 11 (900 – 925cm), Size 12 (925 – 950cm), Size 13 (950 – 975cm), Size 14 (975 – 1000cm), Size 15 (1000 – 1025cm), Size 16 (1025 – 1050cm), Size 17 (1050 – 1075cm), Size 18 (1075 – 1100cm), Size 19 (1100 – 1125cm), Size 4 (725 – 750cm), Size 5 (750 -775cm), Size 6 (775 – 800), Size 7 (800-825cm), Size 8 (825 – 850cm), Size 9 (850 – 875cm) |
Camptech
