Camptech Atlantis DL Seasonal Traditional Full Caravan Awning
Price range: £938.00 through £1,247.00 Inc VAT
Exclusively developed for seasonal pitch camping. Our UK design team have developed this fantastic awning to be the ultimate quality and style, with all the latest innovations in material and design. Available in sizes 9 to 22
The roof and walls are manufactured from all season coated polyester Climatech SR21 material which makes it perfect for a seasonal pitch. The Atlantis Steel 22/25mm Frame consists of our unique Griploc clamps. Included with the frame will be Uniloc Pads to assist in fitting the frame to the side of your caravan. Combining all of these factors together creates a highly durable all season awning.
The setup is made to feel extremely simple. Once assembled the large windows ensure that the Atlantis DL is a bright and spacious environment. If you choose to, these windows can also be zipped out partially or fully to give you more ventilation and to open up your awning during pleasant weather. With the durability of the YKK and Techline Smooth line Zips these help ensure you always have a flush-fitting, easy zip panel.
One of the many great features built into the Atlantis DL is the netted pockets in the side panel of your awning where you can store light reading material and if desired you can lower the privacy blinds to block out light or to create privacy when you vacate the awning. The Atlantis DL also features roll back front panels which is great for an optional wide front door. This item also has fly screen ventilation on both sides which is excellent for additional protection and keeping the insects out.
- Privacy Blinds
- Uniloc Pads
- Techline Zips
- Draught Skirt
- Wheel Arch Cover
- Curtains
- Heavy duty nylon pegs
- Ladder Bands
- Peg Bag
Specifications
- Available in sizes 9 to 22
- Depth – 240cm
- Colour – Anthracite/Light Grey
- Weight – Approx 41kg (size 10 canopy & frame combined)
- Frame: Please note sizes 11-22 are supplied with 2 extra roof poles, sizes 14-22 are supplied with 2 extra front leg poles & sizes 20-22 are supplied with 2 extra roof raiser poles. Depth of this awning is 240cm.
Optional Extras
To enhance your Atlantis DL awning we also have the below optional extras:
- SL500 Techline Secure Straps
- SL580 Techline Secure Plus Strap
- Protech Roof Raiser Pole
- Veranda Poles
- Standard or Tall Annex
- Inner Tents (to be used with the Annex)
- Storm Legs
- Roof Rafter Poles
- LED Lighting System
- Roof Liner
| Sizes | Size 9 (850 – 875cm), Size 10 (875 – 900cm), Size 11 (900 – 925cm), Size 12 (925 – 950cm), Size 13 (950 – 975cm), Size 14 (975 – 1000cm), Size 15 (1000 – 1025cm), Size 16 (1025 – 1050cm), Size 17 (1050 – 1075cm), Size 18 (1075 – 1100cm), Size 19 (1100 – 1125cm), Size 20 (1125 – 1150cm), Size 21 (1150 -1175cm), Size 22 (1175 – 1200cm) |
Camptech
