Campervanbits Hob and Sink Combination unit a great alternative to the likes of a Smev 9222, this new combination hob and sink is ideal for smaller campervan conversions such as a VW T4 T5 T6 T6.1 Transit, Vivaro Bongo etc.
A compact, efficient design and a large gas burner which leaves no space wasted. This sink features electric ignition (12v) comes with plug fittings and the ideal tap diameter is 33mm
The sinks shape makes it easy to set up on the benchtop and it is made from 304 stainless steel. This ensures this is durable product that will provide many years of hard use for you!
Also available for collection in-store – please call 01246825541 for the latest stock levels
• Unit size 900 x 360 x 147mm
• Bowl size: 307 x 217 x 96mm
• Output: 1 x 1.8kW + 1 x 1.0kW
• Body material: SS304/0.8mm
• Glass cover: tempered
• Gas supply: Propane/Butane
• Gas supply pressure: 30mbar
• Gas consumption: 204g/h
• Feedpipe: 8mm gas connection
| Sink Position | RH Sink, LH Sink |
£269.99 Inc VAT
