For use with 7kg & 15kg Butane Gas Bottles
Operating Pressure = 28 mbar
Outlet = 8mm Nozzle
N.B You may find an instructions leaflet stating ‘not to be used in caravans’. European standard EN12864 states that after 2004 all new caravans and motorhomes must be fitted with a 30mbar regulator. The quick- on instructions reflect this standard. Therefore caravans/motorhomes built before 2004 may not have a 30mbar regulator and the appliances may not work at 30mbar, depending on the make of vehicle. Therefore although the use of a quick-on regulator may contradict the instructions the van owner may have little choice. Other than buy a new van!
| Weight | 0.86 lbs |
| Dimensions | 43 × 32 × 4 in |
