This product will only work with a California with the isotop fitted – that has the zip-out front (it replaces that front).
Brandrup flyout for ISO-TOP MK VI for the manual operated pop-up roof with a big front opening of the VW T6.1/T6 California
The front opening of the ISO-TOP MK VI can be removed and swapped with a FLYOUT mosquito net.
FLYOUT makes it more difficult for insects to get into the interior of the pop-up roof.
Perfect view outwards: the mosquito net is black in colour and therefore almost “invisible”.
The view through the front opening is unhindered!
At the sides, the new FLYOUT is attached with zip.
Above FLYOUT is fastened to the black pads, that are needed for the ISO-TOP.
Attention! FLYOUT mosquito net for ISO-TOP MK VI for California VW T6 with front opening should be removed when closing the pop-up roof.
Don’t use FLYOUT when the outside temperature is below 5 degrees Celsius (= 41 °F).
Made in Germany.
100701073
You may also like…
Brandrup Cotton Fitted Sheets for Upstairs Bed of VW California
Price range: £77.99 through £79.49 Inc VAT -
Brandrup Flyout Mosquito Net for ISO-TOP MK VI – Manual Operated Pop-up Roof T6/T6.1
£59.99 Inc VAT
